Date/Time: Wed, 01 May 2024 22:32:05 +0000
sierra chart data feed with existing CQG
View Count: 651
[2020-02-20 19:09:10] |
User298180 - Posts: 7 |
hi i was just wondering if you could clear something up wth me regarding the sierra chart data feed that you supply, I was / still am using the cqg feed from amp futures, If i changed to the sierra chart data feed can I share this with jigsaw daytrader? and how much does this extra connection cost? and do I still keep the cqg feed for order submission and just use this feed to power my charts? or would I use the seirra chart data feed for both data and order submission? are there any advantage s to using this or using this with the cqg data feed? Also doing this would I still get service side oco orders and side trailing stops if using the cqg data feed? thanks
[2020-02-20 19:29:16] |
No, the Sierra Chart data feeds cannot be used with jigsaw. You are definitely much better off using the Sierra Chart order routing service and the Denali exchange data feed as compared to CQG. Server-side OCO orders are not good enough. You need server-side bracket orders which you do not get when using CQG. You will have server-side bracket orders when using the Sierra Chart order routing service. For all of the advantages and set up instructions, refer to: Sierra Chart / Trading Technologies Futures Order Routing Service Server-side trailing stops are not supported though with any service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-20 19:30:08
