Date/Time: Wed, 05 Feb 2025 01:05:19 +0000
Rithmic spread orders rejections
View Count: 598
[2020-02-20 18:54:52] |
User758616 - Posts: 2 |
Hi SC, I created a custom spread symbol via Global Setting: 1*{ESH0-CME}-2*{RTYH0-CME} This spread symbol works in the chart under the simulation mode. I was able to send orders via the Order Entry Window as well as the DOM in the chart, all under simulation mode. However, when I switched to actual trading, the message log said Rithmic rejected the symbol as listed above. Why?? How do I set it up properly under Rithmic datafeed. Thanks in advance |
[2020-02-21 03:53:28] |
It is not supported at this time to trade custom spreads outside of Trade Simulation Mode.
[2020-02-24 17:38:50] |
Hi SC, Do you have an ETA for the implementation to allow trading on custom spread symbols? For the limited time (a few days) I tried the custom symbol spread chart, I have experienced "bad tick" on two days. My OCO order got hit (on one leg in simulation mode) on THOUSANDs points away from the market. I needed to stop the chart and deleted the file and reloaded it to get rid of the bad tick. I hope Sierra Chart would work on the "filter" to make sure that this will not happened during actual trading. The above bad ticks only happened to the "custom spread symbol chart" (under simulation mode) and NOT to the spread chart created using the subchart study "difference" method. I had both charts displaced at the same time hence realized the shortcoming (bad tick - under simulation mode) on the "custom spread symbol chart". So for anyone reading this - you been warned. Hopefully when Sierra Charts finally introduce this feature, they will apply a meaningful and effective "filter" to ensure this will not happened. Yes, the best solution is to trade "Exchanged generated spread symbol" - ah one day! |
