Date/Time: Wed, 01 May 2024 22:50:59 +0000
Why is the Tick Size of 10 Year T-Note Futures now Displaying in 1/34's Instead of 1/32?
View Count: 501
[2020-02-20 16:27:45] |
User521610 - Posts: 9 |
Hello, A client mentioned to me that 10 Year T-Note Futures are now displaying in a tick size of 1/34. The contract specifications on the CME still displays them in 1/32, why was this suddenly changed on Sierra Chart? We have checked on both CQG and Rithmic data and the tick size seems to be displaying as 1/34 on both. I know you can change tick size using Global Settings > Symbol settings, but we wanted to get an answer first before reconfiguring things. Thanks for your help. |
[2020-02-20 17:58:37] |
There is a technical notice about this when you start Sierra Chart. You need to update to the current version to resolve this. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
