Date/Time: Wed, 01 May 2024 23:08:06 +0000
CTS Data Feed does not work (AMP)
View Count: 603
[2020-02-20 06:32:07] |
User363388 - Posts: 5 |
Hey guys, i´m using Sierra Chart via AMP and i wanted to try out a new data feed because i´m thinking about switching from CGQ to CTS/Denali. I registered for the 2 Weeks CTS trial. But when i enter the CTS credentials via file->data/trade service settings i´m getting this message in the message log: CTS T4 FIX | Connection to non-affiliated broker not allowed. | 2020-02-20 07:20:03.926 * AMP said i have to talk to CTS to solve this. But they just said i have to use the simulated server which or so does not work. Maybe someone already had the same problem with the trial data feed. Thanks in advance. |
[2020-02-20 10:09:57] |
We strongly recommend using the Sierra Chart order routing instead: Sierra Chart / Trading Technologies Futures Order Routing Service You will save money and get a much higher quality of service. Users should trust what we say. We have a lot of inside knowledge. From the Sierra Chart perspective CTS is considered a legacy service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-20 10:10:33
