Date/Time: Fri, 03 May 2024 01:42:04 +0000
broker
View Count: 451
[2020-02-19 19:23:03] |
stephane1 - Posts: 110 |
hi, Have you got a broker list that allows the use of sierrachart.. regards |
[2020-02-20 02:43:05] |
Yes have a look at this page: https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
