Date/Time: Wed, 05 Feb 2025 00:58:45 +0000
[User Discussion] - Custom indicators
View Count: 1431
[2020-02-19 18:13:57] |
User21223 - Posts: 92 |
Custom indicators do not load. After uploading the new version of Sierrachart An example indicator in the attachment Date Time Of Last Edit: 2020-02-19 18:14:20
scanVol_b1.dll - Attached On 2020-02-19 18:13:01 UTC - Size: 93 KB - 389 views Attachment Deleted. |
[2020-02-19 23:22:25] |
Ackin - Posts: 1865 |
try "Safe mode" Sierra Chart - Software Login Instructions: Using Safe Mode |
[2020-02-20 07:58:30] |
ganz - Posts: 1048 |
User21223 In order to be sure. ...is this one of mine old time indi? if so .. it was compiled using 32 bit tools |
[2020-02-21 19:41:41] |
try "Safe mode" does not help ganz Yes it's your indicator. I used it and it worked. Until I updated the Sierrachart. So it won't work on the updated Sierrachart. |
