Date/Time: Fri, 03 May 2024 01:32:28 +0000
Spreadsheet study
View Count: 417
[2020-02-19 18:04:21] |
User21223 - Posts: 90 |
I used the option here USE EXCEL. Why is this option still not for Spreadsheet study
[2020-02-19 18:28:31] |
This is from the What is New page: Support for direct integration between Sierra Chart and Microsoft Excel has been removed. One reason among others that support for Excel has been removed is that Sierra Charts internal core is no longer going to be using MFC and interfacing to Excel becomes very complicated using the lower level windows COM functionality and it is not a well-documented area of the operating system. We are working on alternatives to this feature, like automatic saving of the data on a Sheet used by the Spreadsheet Study to a tab delimited file.
