Date/Time: Sat, 03 Oct 2026 02:26:56 +0000
Time & Sales Coloring and Recording
View Count: 1039
| [2020-02-19 15:06:16] |
| tdd2672 - Posts: 63 |
I have time & sales pulled up from two separate charts. One is set to Bid Size and the other to Ask Size. The volume is recording differently for each however the coloring is still displaying both bid and ask colors on both. How can this be adjusted? Also, are bid/asks getting reported at the same time? I ask because both T&S windows move in sync. As it is I can not differentiate between the two or detect if one or the other is stronger or moving faster/getting more hits.
| [2020-02-19 18:44:24] |
We are not understanding your question about colors. You would need to filter out the Bid trades from the one displaying the Ask and vice versa. Refer to the information on the filtering options here: Time and Sales Window: Time and Sales Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-02-20 15:01:56] |
The issue I've run across with filtering is that when I enter 0<= for max volume it will not save. So it always shows a minimum of 1.
| [2020-02-20 22:41:06] |
Can you explain what I need to do to correctly filter out all bid or ask trades/volume?
