Date/Time: Wed, 05 Feb 2025 10:45:16 +0000
Volume profile Peaks & Valleys issue
View Count: 1327
[2020-02-19 07:51:36]
User350195 - Posts: 34
VbP Peaks & Valleys are not calculated correctly when switching Volume Bar Calculation Method from Total to Diagonal. They're still using Total volume levels instead of Diagonal.
Please advise.
[2020-02-19 16:27:32]
John - SC Support - Posts: 37728
The Peaks and Valleys do always use the Total Volume at each price level rather than the value set in the Volume Bar Calculation Method. We have updated the documentation to reflect that this is how it works. You will find the information here:
Volume By Price Study: Draw Peaks and Valleys
[2020-02-19 18:05:08]
[2020-02-23 12:57:54]
We will see if it is not difficult add support for this.
Date Time Of Last Edit: 2020-02-23 12:58:00
[2020-02-26 09:36:54]
[2020-02-28 20:36:16]
We should have this out in the next release.
[2020-03-09 21:51:20]
This has been released.
[2020-03-13 17:46:13]
Hello are you still following this thread?
there's a new issue:
when Volume Bar Calculation Method is set to Ask Volume - Bid Volume. PoC and Value Areas are calculated incorrectly.
