Date/Time: Thu, 24 Sep 2026 21:31:04 +0000
Les bons du trésor
View Count: 847
| [2020-02-18 18:53:53] |
| christophe - Posts: 3 |
Bonsoir, j'ai activé tout les bons du trésor (UB,ZN,ZF et le ZB) et sierra chart m'ouvre les graphiques et me dit ( symbol is unknow.click for symbol information. unsupported symbol.) comment dois-je faire? merci |
| [2020-02-19 10:41:18] |
Make sure these symbols are translated to the current service you are using with Sierra Chart. To do this, select Edit >> Translate Symbols to Current Service. Refer to the following for complete documentation: Edit Menu: Edit >> Translate Symbols To Current Service If these are new charts, then make sure you are selecting the symbol from the File >> Find Symbol window in order to make sure that you have the correct symbol for the current Data/Trade Service Setting. Refer to the following for more information: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-19 10:41:37
