Date/Time: Tue, 04 Feb 2025 22:47:07 +0000
TPO Study Chart Zoom-In-Out Behavior
View Count: 520
[2020-02-18 14:37:26] |
HinckleyBob - Posts: 45 |
Striking the Home-End keys with all TPOs collapsed produces un-usable results on the attached NQ chart. I would expect the current price to be centered in the window, with the width of the bars the same when at the end of the chart, as at the beginning. An identically configured attached CL chart behaves correctly. Please help me configure the NQ chart correctly, or help me work around the problem. Thank you, Bob |
CL Home-End key NO problem.Cht - Attached On 2020-02-18 14:36:24 UTC - Size: 55.8 KB - 253 views NQ Home-End key problem.Cht - Attached On 2020-02-18 14:36:32 UTC - Size: 77.37 KB - 331 views |
[2020-02-19 15:45:11] |
John - SC Support - Posts: 37726 |
Really we just recommend that use a constant range scale for the charts: Chart Scale and Scale Adjusting: Constant Range (Scale Range) And if necessary reset the scales with Chart >> Scale >> Reset Scales. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
