Date/Time: Mon, 20 May 2024 15:57:56 +0000
chart showing earlier data which is not in the setup
View Count: 529
[2020-02-17 20:05:55] |
User61576 - Posts: 418 |
pls check attached screenshot the data is set to start on 2020-02-03 and I get data from 23:00 the day before pls advise thanks |
why getting data before usedate.png / V - Attached On 2020-02-17 20:05:12 UTC - Size: 157.53 KB - 193 views |
[2020-02-17 23:03:04] |
For an understanding of this, refer to: Chart Session Times: Understanding Trading Day Dates Based on Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-18 05:45:50] |
is this session info is inherited from the exchange? as ES has one session time which is different from CL which is different from GC
[2020-02-18 18:20:20] |
The Session Times that are set by default are in the Symbol Settings. You can change the information there if it is not matching what you think it should be. Most symbols should match the hours of the exchange. Refer to the following: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-18 18:20:37
