Date/Time: Wed, 05 Feb 2025 03:58:24 +0000
Pro cents on the charts.
View Count: 1044
[2020-02-17 18:30:17]
User344478 - Posts: 148
There are pro cents in BUY and SELL columns on the DOM, for each price. Is it possible to see the same pro cents, on the charts, (or BUY, or SELL)?
[2020-02-18 18:16:00]
We are not understanding this. Can you provide an image of the Trade DOM following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
[2020-02-20 15:38:51]
"For the case of a Trading DOM, select Chart >> Upload Chart with Overlays ."
I select Chart, but in the chart there is no 'Upload Chart with overlays". I have used Edit >> Screen Images >> Upload chart with overlays. But I do not notice a message box appear and do not press yes to copy the link of the upload image of the DOM. I go to message on the Support Board, right click in the area where I type message and select the PASTE command to paste the link. The result you can see.
[2020-02-21 07:40:30]
The image upload issue will be resolved when you update Sierra Chart to the current version following the instructions here:
But this is definitely valid in the case of the version you are running:
Date Time Of Last Edit: 2020-02-21 07:41:07
[2020-02-21 15:41:41]
I update Sierra Chart to the last version 2054. I select Chart, but in the Chart there is no 'Upload Chart with overlays". I would like to ask the same question differently. There are percent in the column Bid quantity and in the column Ask quantity in Market Depth Window. The same percentages are shown in the columns BUY and SELL on the DOM, for each price. Is it possible to see the same percent or BUY percent or SELL percent, on the charts?
[2020-02-28 20:24:19]
There are percent in the column Bid quantity and in the column Ask quantity in Market Depth Window. The same percentages are shown in the columns BUY and SELL on the DOM, for each price. Is it possible to see BUY percent or SELL percent, on the charts?
[2020-03-02 00:49:00]
Sierra_Chart Engineering - Posts: 18262
You can do this with the DOM Graph:
Trade Menu: Draw DOM Graph on Chart (Trade menu)
There are options to display the percentages. Let us know if this is what you are looking for.
[2020-03-02 00:49:06]
Another way to do this through several studies:
You would need to do the following:
- Put on a Bid & Ask Depth Bars study and set the Calculation Mode to Bid Depth vs Ask Depth
- Add a Spreadsheet Formula study and put in a formula that looks like this: =ID1.SG1 / (ID1.SG1 - ID1.SG2)
Where ID1 is the ID of the Bid & Ask Depth Bars study
- Add the Text Display for Study study and set the Study and Subgraph to Display to the Spreadsheet Formula and Result (respectively).
This will give you the Ask Depth Percentage displayed in the Chart wherever you want it. You would have to repeat steps 2 and 3 to get the Bid Depth and change the Subgraphs accordingly.
Date Time Of Last Edit: 2020-03-02 00:50:09
