Date/Time: Mon, 20 May 2024 14:58:22 +0000
CTS T-4 data
View Count: 479
[2020-02-17 15:36:42] |
User435059 - Posts: 14 |
Hello !!! i just find out you dont support CTS t-4 CBOT data? i see i,m getting data from SC server this is free data ? also i see braket OCO order on client side , i set in general property to server if possible do you stop supporting server side order ? T-4 still offer server side |
[2020-02-17 20:39:29] |
Due to changes by CTS there is a problem with market data for some CBOT bond futures markets when using CTS. You will need to use this service instead of CTS: Sierra Chart / Trading Technologies Futures Order Routing Service There are some scenarios based on the particular attached order configurations, where the bracket order may still be held client-side. It depends upon the order types. What are the order types? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
