Date/Time: Mon, 06 May 2024 05:18:16 +0000
Drawing sets
View Count: 575
[2020-02-16 15:57:56] |
Csurles2010 - Posts: 13 |
Hello all, Is there a way to create drawing sets. For example, I have support/resistance zones in 1 drawing set. Then I could have Fibonacci confluence levels on another drawing set. Currently I have all drawings on 1 chart and manually hide and unhide them. I am looking for a simple way to switch between different drawing sets without creating a new chart. This would greatly speed up my analysis. Is there any way to do this without manually hiding them or having several open charts for different drawing sets? Thank you, Corey |
[2020-02-17 00:32:16] |
The concept of Drawing Sets does not exist. We think the best way is just to use separate charts for the different sets you want.
