Date/Time: Thu, 24 Sep 2026 01:49:09 +0000
OCO bracket with TT/Sierra order routing - server side functionality
View Count: 1401
[2020-02-16 01:40:58]
nosast - Posts: 324
I have a question regarding the bracket order functionality with TT/Sierra order routing.
Let's say I enter a LMT oder with a bracket (TGT 3 pts / STP 3 pts) and right before I get my fill I lose my connection due to internet issues. The LMT order is for sure right at the CME matching engine. What happens if the LMT got triggered and I'm in a position. Will the bracket still be set properly from server side or is the position open without any stop and target?
[2020-02-16 09:32:01]
When using a server-side Bracket order, it does not matter if you lose the Internet connection on your side. The orders are managed on the server. So both the Stop and Target order will be sent.
[2020-02-16 09:47:47]
nosast - Posts: 324
That‘s perfect. I was sure about the brackets being managed server side once they are entered from client side.
Even better if before the order gets filled the server side „knows“ that there are brackets attached with this entry limit order and will sent them even if there is no connection to the client.
[2020-02-16 09:53:13]
Yes this is certainly the case.
