Date/Time: Tue, 26 Nov 2024 06:39:07 +0000
[User Discussion] - Delta Divergence Arrows--Repaint?
View Count: 2008
[2014-01-06 21:01:39] |
User93252 - Posts: 2 |
Hey there, I have the delta divergence indicator up on my charts with its arrows, and I was wondering if this indicator repaints or does it paint at the close of the current bar? thanks for your help, tiago... |
[2014-04-16 16:52:14] |
cmet - Posts: 551 |
Yes, this seems to have a lookback and only plots on the close. It would be much better if it plotted in real time (intrabar). Even if it flickered on/off, it would be much more beneficial for helping with entry timing. |
[2014-04-16 17:55:06] |
User54027 - Posts: 128 |
It does paint at the close of the current live bar. I use it extensively. Tonights action on the dax http://prntscr.com/3al1kr |
[2014-04-16 17:59:19] |
cmet - Posts: 551 |
Great indicator no doubt but if you're using certain bar types (such as range bars greater than 6 ticks) you can't use it to support an entry on the same bar where it occurs as the bar is forming. Well, you can I guess but you increase your risk. Would be very useful to have a 0 lookback for intrabar plotting. |
