Date/Time: Mon, 06 May 2024 02:44:00 +0000
After upgrade from SC Version 2028 to 2050 Quoteboard chartlinking not working as before
View Count: 457
[2020-02-15 17:25:24] |
User197029 - Posts: 45 |
I have a chartbook which contains historical and intraday charts. My symbols are saved in a quoteboard which is linked to the charts. Until now whenever I clicked on a symbol in my quoteboard all charts changed to this symbol maintaining their Bar Period and Chart Data Type setting, ie a Historical Chart remained a Historical Chart and a intraday chart remained an intraday chart. Since the new version whenever I click on a symbol in the Quoteboard all historical charts become intraday charts. I found a way around this and it was to untick the Bar Period box in all the charts, however this is not satisfying since I can now not switch quickly from Daily to Weekly or any other timeframe charts anymore. I will have to select each historical daily chart individually and switch to the desired timeframe. As soon as I link the charts via bar period any click on a symbol in the quoteboard changes the charts to intraday charts. In short I am not able anymore (as in previous versions) to scroll through historical and intraday charts on the same chartbook via my quoteboard. I have tried with associated watchlists instead of quoteboards. Here the linking still works fine, however for my purposes I would need to work with quoteboards as I am using the comment field a lot. Help much appreciated. |
[2020-02-15 23:12:29] |
We are looking into this now.
[2020-02-16 01:36:54] |
This is now resolved. Update with Help >> Download Prerelease for the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
