Date/Time: Sun, 24 Nov 2024 01:24:51 +0000
Read Trade window parameters in ACSIL
View Count: 945
[2020-02-15 10:58:20] |
HAB-User115006 - Posts: 38 |
1. How can I read the target/Stoploss values in ACSIL like I can read quantity using sc.TradeWindowOrderQuantity 2. If the above is not possible is there a way to read the TW TextTag value When placing orders I am using sc.UseGUIAttachedOrderSetting = 1 to use the TW attached orders and I intend to display TW settings on the chart so I know what is being traded in case I change a TW parameter. Thanks |
[2020-02-16 10:40:28] |
1. You cannot. You can only set them: sc.SetAttachedOrders() 2. We will have to add a function for this. This will be out in the next release: int (SCDLLCALL* GetTradeWindowTextTag)(SCString& r_TextTag); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-21 02:32:48] |
That is great Quick note: This function should Read the Config name if the 'Use Config name as Text tag' option is checked Thanks a lot... |
[2020-02-21 18:45:14] |
2. This function has been added in the latest prerelease of Sierra Chart. Quick note: This function should Read the Config name if the 'Use Config name as Text tag' option is checked
Ok we will implement this.
