Date/Time: Mon, 06 May 2024 07:06:48 +0000
VA Boxes in TPO chart
View Count: 566
[2020-02-14 22:08:08] |
MarcOh - Posts: 162 |
Hey there, is it possible to show the VA in TPO profile like in the following example? already tried TPO value area lines. No positive results. Thank you! |
Attachment Deleted. Screenshot_13.png / V - Attached On 2020-02-14 22:07:47 UTC - Size: 232.98 KB - 282 views |
[2020-02-15 04:26:03] |
It is possible to color the background of the TPOs that make up the Value Area. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Highlight TPO Value Area Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-15 07:20:03] |
This is also pretty cool. THX. problem is: Also the open of each period is specific background colored now? :) I will figure it out how to fix. Thx guys!
Date Time Of Last Edit: 2020-02-15 07:22:10
