Date/Time: Tue, 04 Feb 2025 21:53:45 +0000
Cannot get 1 tick chart to load
View Count: 883
[2020-02-14 18:28:31] |
User928528 - Posts: 20 |
I cannot seem to get a simple intraday chart on the tick scale to open (Bitmex, XBT chart). I believe I have followed your instructions correctly: In the global settings >>> data/trade service settings, I have Intraday Data Storage time Unit set to 1 tick. In my chart settings, I have my chart settings as attached (see picture). I did initially download a 1 minute chart and that was fine. I understood that I had to delete all data and download which I did to no effect. I still only get a 1 minute chart no matter what I seem to do. Please help. |
Capture.JPG / V - Attached On 2020-02-14 18:27:32 UTC - Size: 199.78 KB - 238 views |
[2020-02-14 20:00:53] |
What do you see in the chart itself? We cannot fully see the chart. Is it completely blank? Maybe you are not using the right symbol. If you want the bitcoin versus the dollar symbol, use: XBTUSD-BMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-14 20:01:12
[2020-02-14 20:51:28] |
Ok that seems to have done the trick. I was using the wrong symbol. Thanks.
