Date/Time: Sun, 05 May 2024 21:27:57 +0000
OHLC List
View Count: 495
[2020-02-14 13:30:13] |
John Ara - Posts: 125 |
Please let me know if I can export daily OHLC data out of sierra? Thank you. |
[2020-02-15 05:05:05] |
The .dly files are text data files that have this information. You can just open/copy the files directly, you do not need to export anything.
