Date/Time: Tue, 04 Feb 2025 21:57:15 +0000
data and routing issues after switching providers
View Count: 591
[2020-02-14 12:37:12]
User574852 - Posts: 1
I switched my account over to the Denali data feed which also required a new futures account. I use Stage 5 and they switched me to Advantage Futures from a Gain account. When my data/trade service connection is set to Gain/OEC I receive Bid/Ask data and it appears to be Denali based on the increased levels of depth on the dom. However, when following the instructions to switch to the Sierra order routing I loose the data feed. I've been in contact with Stage 5 numerous times with little help.
[2020-02-14 16:33:59]
Follow the instructions here beginning with step 9:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
And use this Edit menu command to translate the symbols:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
Date Time Of Last Edit: 2020-02-14 16:34:44
