Date/Time: Wed, 05 Feb 2025 00:58:39 +0000
Sierra don't work with two accounts from Bitmex
View Count: 778
[2020-02-14 09:33:38]
User452429 - Posts: 20
Hello!
Can you help me?
Sierra don't work with two accounts from Bitmex - any updates near 2-3 hours.
Payment - is ok.
API - is ok.
System is 64bit.
Also I've checked then field "Find symbol" is free without any trading symbols and this message: The response for symbol setting was empty, so the symbol settings file was not created.
How I can find avalianle symbols?
I meant that I don't have this menu:
"""To open a chart select File >> Find Symbol from the main menu. In the list, select BitMEX >> Get BitMEX Symbols to access the Live data and trading symbols. Or, select BitMEX Testnet >> Get BitMEX Symbols to access the Testnet data and trading symbols."""
What else I need to do?
Thanks in advance.
imageСиерра.png / V - Attached On 2020-02-14 09:33:28 UTC - Size: 53.5 KB - 226 views
[2020-02-14 14:46:47]
Also one more problem. When I try to open position - Sierra is open Trade Simulation mode on instead real trading. How I can solve this?
[2020-02-14 14:53:50]
SC Data - is working all - symbols, etc, but not real trade!
Bitmex trading - not working (message - download failed).
Version of Sierra 2048-2049.
I can't wait long time (I've pay for Sierra account each month).
imageСиерра.jpg / V - Attached On 2020-02-14 14:53:08 UTC - Size: 89.62 KB - 266 views
[2020-02-15 05:06:10]
The problem with the File >> Find Symbol window being empty is resolved. Open that window again.
[2020-02-15 11:41:16]
I've do this and I can't trade with real money, because Sierra is open Trade Simulation Mode instead real trading.
When I try to open real order - Sierra all time open orders with Trade Simulation Mode.
I turn it off all the time and still it turns on automatically.
Also when I've open Data/Trade Service Setting and open Bitmex Trading Direct - any updates on charts!
When I've open SC Data - All Services - I see updates but Sierra all time change real trading to simulation!
Date Time Of Last Edit: 2020-02-15 11:46:03
imageСиерра.jpg / V - Attached On 2020-02-15 11:44:34 UTC - Size: 89.62 KB - 255 views
[2020-02-15 11:53:36]
I don't know, maybe I can use your online help with teamviewer?
Because I see good momnet to open position with BTC, but I can't trade with real money...
I have download app for Remote Assistance Support.
How can I contact with your specialist?
Thanks in advance!
Date Time Of Last Edit: 2020-02-15 12:20:02
[2020-02-15 13:58:44]
One moment:
Swap ETH/USD - is working!
Wow, but XBT/USD (BTC) - not working. What is the problem?
[2020-02-18 17:56:03]
You do need to set Sierra Chart to use the BitMex Trading Direct service. Instructions are on this page:
BitMEX Trading Service
Otherwise, the orders will be simulated.
And you also have to disable Trade Simulation Mode:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
And the symbol to use would be XBTUSD-BMEX
Date Time Of Last Edit: 2020-02-18 17:56:13
[2020-02-22 00:11:16]
I've downloaded a full version of Sierra and all are working.
