Date/Time: Mon, 25 Nov 2024 01:33:10 +0000
Changing Chart number in ACSIL
View Count: 1322
[2014-01-06 19:56:26] |
WarriorTrader - Posts: 245 |
Hello, I have many studies that display chart tools on a different chart number than the chart the study is on by changing the chart number of the tool: TextTool.ChartNumber = 7; After upgrading to 1070 form 950, I can no longer change the chart number of a drawing tool in ACSIL. I am using this feature in 5 different studies. I can post a simple example if you need it, but the problem is pretty self-explanatory. Thx, WT |
[2014-01-06 20:37:37] |
Please check the documentation for that variable: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html There have been some changes recently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
