Date/Time: Wed, 12 Feb 2025 11:44:36 +0000
[User Discussion] - Ask Volume Bid Volume Difference Text Swing Delta Numbers?
View Count: 1910
[2020-02-13 23:22:06]
User628616 - Posts: 132
On this Study (Ask Vol/Bid Vol Diff. Text) is there anyway to have it calculate Swings for Delta instead of each bar? In the pic its each bars Delta that's displayed in Red and Green. I drew a couple of Swing/Pivots(Purple Lines) I'll like it to display Swing Lo to Swing Hi Delta, then the following Swing Hi to Swing Lo Delta and etc.
imageCaptureC.PNG / V - Attached On 2020-02-13 23:16:43 UTC - Size: 29.07 KB - 652 views
[2020-02-16 12:42:33]
Ackin - Posts: 1865
A similar request has already been solved...Do you want like this?
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=29347
If "yes" then:
https://www.sierrachart.com/AdditionalFiles/ZigZagAccVolumeColorByPosNeg.StdyCollct
Follow the instructions here for how to use this study collection:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
[2020-03-15 16:35:32]
I downloaded and added the Study you posted, and this is what came up on charts, its still displaying the cumulative delta for each bar instead of each swing like it does here:https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=29347
What do I need to do?
imageF.US.ENQM20 [CV] 1 Min #3 2020-03-15 11_34_06.037.png / V - Attached On 2020-03-15 16:34:27 UTC - Size: 50.81 KB - 480 views
[2020-10-22 00:37:48]
User459170 - Posts: 262
Is there some way to remove the 00s after the decimal in this text display?
