Date/Time: Mon, 25 Nov 2024 02:11:30 +0000
How do I send a link for the Charts tutorials for a Student?
View Count: 2811
[2014-01-06 17:27:53] |
spartan forecasts admin - Posts: 21 |
For Dirk .
Date Time Of Last Edit: 2014-01-06 19:14:54
[2014-01-06 18:07:26] |
What particular chart tutorial are you referring to?
[2014-01-06 18:11:06] |
He needs to start over and refresh himself
[2014-01-06 18:28:06] |
Are you there?
[2014-01-06 18:51:42] |
Hello?
[2014-01-06 19:15:49] |
We are just getting back to this now. You can find the Sierra Chart set up instructions here: http://www.sierrachart.com/index.php?l=doc/setup.php And on this page, is our Getting Started/Tutorial: http://www.sierrachart.com/index.php?l=doc/doc_GettingStarted.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-06 19:16:04
[2014-01-06 19:30:16] |
Is anyone there?
[2014-01-06 19:31:29] |
We responded at post #6. Scroll up this page.
