Date/Time: Fri, 10 May 2024 06:48:03 +0000
Study
View Count: 532
[2020-02-13 15:26:08] |
User871865 - Posts: 11 |
Hello I have another question. I've had Sierra Chart for a long time and since I've been using Sierra Chart through AMP. My study (Anchor VWAP) has disappeared. Can you help me ? Thank you
[2020-02-13 20:46:38] |
For some reason you are running in Safe Mode. When this is the case, you are not able to load any studies that were not provided by Sierra Chart. If you no longer need to be in Safe Mode, then turn this off when starting Sierra Chart and you will be able to see your study in the list to load again. Refer to the following: Sierra Chart - Software Login Instructions: Using Safe Mode Also refer to this page: Resolving Custom Study File and Access Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
