Date/Time: Thu, 09 May 2024 21:28:38 +0000
DOM PLY does not reset from the previous day
View Count: 467
[2020-02-13 15:03:14] |
User461746 - Posts: 11 |
When I log on the DOM shows the previous days PLY Any ideas what the problem is? |
[2020-02-13 16:06:53] |
jake206711 - Posts: 9 |
Having the same problem and then the DPL resets at 1030 EST. computer Clock is correct, Time zone is correct. I haven't knowingly changed anything. SC 2048. CQG and AMP Futures.
[2020-02-13 19:17:17] |
You need to update to the current version to resolve this: Software Download: Fast Update In 2048 it does automatically reset. However, refer to the documentation here for an understanding of how this works: Trade Activity Log: Understanding Daily Trade Statistics Reset Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-13 19:19:41
