Date/Time: Fri, 10 May 2024 15:19:53 +0000
Draw volume profile visible on specific chart
View Count: 459
[2020-02-13 07:08:19] |
User78682 - Posts: 7 |
Hi support, Is that anyway can the drawn volume profile only visible in the current chart or time frame it was drawn. I have a quote board with more than 1 instrument, when drawn volume profile will also be visible when click on other symbol, is that anyway can I only have the profile visible on specific chart/time frame? Thanks. |
[2020-02-13 07:26:56] |
Yes. But this only applies to the symbol. This is the relevant option: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
