Date/Time: Fri, 10 May 2024 01:45:46 +0000
SC order routing with TT fix - FCM/IB options
View Count: 547
[2020-02-12 22:56:29] |
grayfrog - Posts: 35 |
Currently the list of FCM/IBs that support the TT fix connection are listed as: ADM Investor Services Advantage Futures AMP Global Clearing Dorman Trading ED&F Man Capital Markets G. H. Financials Stage 5 Trading Wedbush AGN Futures (Any other futures clearing firm supporting Trading Technologies) With regards to the last line there, are there any others that you can confirm Sierra Charts has connected to without issues? |
[2020-02-13 03:09:17] |
There is also Phillips Capital but they will charge extra when using TT.
