Date/Time: Fri, 10 May 2024 05:39:13 +0000
Numbers Bars Daily
View Count: 507
[2020-02-12 18:41:00] |
User315851 - Posts: 27 |
I am trying to use Numbers Bars where each column is a 1-DAY worth of information. This info includes volume traded at different prices as well as ticks traded in that 1-DAY. The attached picture shows ticks that are gapped, which is incorrect. How do I go about achieving what I am looking to see?
NumbersBars.JPG / V - Attached On 2020-02-12 18:36:42 UTC - Size: 46.73 KB - 239 views Attachment Deleted. |
[2020-02-13 06:35:51] |
The Numbers Bars study can only be used on Intraday data. Therefore, if you want to use a Daily period, you would need to change the Chart Data Type to Intraday Chart Only and then choose a period of Daily. Refer to the information here: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) And you also need to make sure the Volume at Price Multiplier is set to 1: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
