Date/Time: Fri, 10 May 2024 18:39:47 +0000
[!!PROBLEM!!]overlapping orders on bonds (ZF)
View Count: 740
[2020-02-12 14:10:29] |
SebastianMarquez - Posts: 3 |
hello support, after I update Sierrachart to version 2049, I have problems with the limited orders in the bonds (ZF) since the limited ones overlap. How can I fix it ?, send image Thank you |
2 YRS treasury bonds problems.png / V - Attached On 2020-02-12 14:09:21 UTC - Size: 35.6 KB - 207 views Attachment Deleted. |
[2020-02-12 15:37:19] |
We are working on getting this resolved. Just give us about 10 minutes. And we will give you further instructions.
[2020-02-12 15:49:10] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings This will resolve the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-12 16:06:57] |
thanks, this solution solved the problem
