Date/Time: Fri, 10 May 2024 02:24:49 +0000
SC Data with IB
View Count: 506
[2020-02-12 12:03:53] |
sectel - Posts: 12 |
Is it possible to use SC data but trade directly from charts using IB as the brokerage? I have upgraded to a more expensive version of SC and I am still having issues with IB data. This was never a problem in the past and must be systematic of current versions of Sierra as I know IB has not altered their data. J. |
[2020-02-13 09:43:32] |
Yes it is. What is the specific issue you are having? Regarding historical data, follow the instructions here: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-13 09:44:03
