Date/Time: Fri, 10 May 2024 04:11:28 +0000
question re: backing up Sierra Charts
View Count: 513
[2020-02-12 02:04:42] |
User708302 - Posts: 6 |
Hi, I'd like to know which files in my "SierraChart" folder on my C: drive I should back up in order to save my chartbook plus the way it's laid out (want it on a flash drive). Specifically I mean the color and shape of my candles, my chart timeframes, the products I have in my Quote Board, that I have 3 charts that appear on all 3 of my monitors at once, etc. I took a guess and have been backing up the entire "Data" folder but it's now 12 GB. I see a "Backups" folder but not sure if that's what I need. Thank you!
[2020-02-12 19:46:06] |
Refer to the information here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Although it is about copying the data to a new installation, it will give you the information on what files you would need to copy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
