Date/Time: Sat, 15 Mar 2025 08:01:01 +0000
ASX Australia Market
View Count: 1959
[2020-02-12 00:49:16] |
vish100 - Posts: 111 |
Hi, Are there ASX Australia market instruments covered by Sierra charts? Thanks |
[2020-02-12 16:03:08] |
User495158 - Posts: 108 |
I think not, you have to use CQG/ AMP for trading on SFE. Try searching the support board. There were posts abot that already.
[2020-02-14 03:07:49] |
Yes checked those posts. I thought it can be done via interactive brokers? thank you
[2020-02-14 03:47:28] |
We are working on the possibility of adding this exchange. If we are able to do this, it would not likely be available until about 4-6 months from now. However, it is something we are actively working towards.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-14 03:48:01
[2020-02-14 04:32:48] |
However in 'Included Markets' it does show ASX
[2020-02-14 04:40:37] |
Yes there is this data available but it is not streaming data. Do you need the charts continuously updating or is updating every 10 minutes acceptable?
[2020-02-14 05:05:03] |
Yes I need real-time data i.e charts updating continuously. So if I understand correctly the issue is with interactive brokers? If yes, will it work with AMP futures? thanks V |
[2020-02-15 23:39:59] |
Understood. We do not recommend Interactive Brokers market data. ASX data is available through CQG when using AMP. CQG is supported by Sierra Chart.
[2020-02-17 10:15:14] |
Thanks that makes sense. However I use IB and do not want to use another broker. Is it possible to use CQG data feed --> SC --> IB i.e. CQG data feed with SC and IB? I have seen some posts on this topic last year but they are too long and techie. Will appreciate help if this is possible? Thanks |
[2020-02-17 11:33:38] |
Yes but it is complicated, sort of. And we are working to offer the ASX real-time data as soon as we can. Anyway here is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-17 11:35:03
[2020-02-20 05:32:16] |
Hi, You mention about CQG being available via AMP. However I saw a sticky post recommending not to use CQG Can you please comment? thanks |
[2020-02-20 10:56:44] |
Yes but that recommendation only applies for the CME group of markets. Since we have a better alternative in that case. For other markets CQG would be the only other reasonable choice other than Interactive Brokers but we expect this to change hopefully by June this year once we have the real-time ASX data (hopefully) and then you can use our TT order routing. You could then use that order routing service with a broker in Australia which would be affiliated with Macquarie(Bell Potter). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-20 10:57:57
[2020-02-29 23:00:35] |
Hi, I am setting up an account with AMP futures with CQG data feed for Australian SFE. It has 3 options 1) Package 3 - Free for (AMP direct customers) 2) Package 5 - $25 charge 3) None - you purchased your own license from SC Considering I have my own account with SC, can I still choose Package 3 I read in one of the posts - "For access to Sierra Chart through AMP you need to rely on them. We cannot help you with that. " So will the support not be good if I choose option 1 AND will I need to set up my SC platform again if I go with option 1 thanks |
[2020-03-02 05:59:22] |
We definitely recommend maintaining your own direct Sierra Chart account. So stay with option 3 above.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 05:59:31
[2020-03-04 03:03:23] |
Hi, By putting my username/password in the data/trade service settings, I am able to connect to CQG - AMP for trading ASX SPI However when I am connected, I get disconnected from the CQG Desktop login with 'Concurrent Session' message. I know that you do not support this but how are people dealing with it? This problem does not arise with IB. Also if I trade only using SC without being logged into CQG, will all my trades go through and be executed correctly on CQG/AMP? thanks Vishal |
[2020-03-04 12:23:14] |
Also if I trade only using SC without being logged into CQG, will all my trades go through and be executed correctly on CQG/AMP? And you will not have this problem when using the Sierra Chart order routing service. So when we have ASX market data available you would not need to use CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-19 02:56:19] |
User753526 - Posts: 54 |
Hi. I was searching for an ASX feed for Sierra Charts also. I see this is dated from 2020, is there by any chance that an ASX Exchange feed for futures and/or stocks was further established?
[2022-07-19 08:41:56] |
No, definitively, we are not adding anything from Australia. Out of the question. Never going to happen.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-19 08:42:08
