Date/Time: Mon, 21 Apr 2025 04:47:17 +0000
change size and font of chart studies and study settings windows
View Count: 835
[2020-02-11 19:26:58] |
sjk - Posts: 43 |
How do I change size and font of chart studies and study settings windows
[2020-02-11 23:24:20] |
This is not currently supported but we are working on this capability. It should be out in a few months. Actually we hope may be to have the initial release out maybe in two months or so.
[2023-02-02 17:29:52] |
j4ytr4der_ - Posts: 946 |
Did this feature ever get implemented? I'm also looking to change the font of a particular study, but can't figure out a way to do it.
[2023-02-02 18:41:59] |
John - SC Support - Posts: 39362 |
What exactly are you wanting to do? Depending on what you are displaying, the Subgraph Width/Size may give you want you are wanting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-02 19:28:29] |
I want to change the font itself, unfortunately.
[2023-02-02 23:01:05] |
Sorry, you can not change the font for just a single subgraph, or a single study.
