Date/Time: Tue, 04 Feb 2025 22:10:05 +0000
Spreadsheets error
View Count: 621
[2020-02-11 18:06:25] |
pismo10 - Posts: 159 |
Unable to open 2 scwbf files as spreadsheet conversion process failed.. ..and very cleverly it simply tries forever, posting a new error msg every 1/2 second or so. Thanks. |
[2020-02-11 20:28:40] |
Privately attach the files here and we will convert them for you.
[2020-02-12 13:46:18] |
Thks
Private File Private File Attachment Deleted. |
[2020-02-16 08:21:50] |
Sierra_Chart Engineering - Posts: 18250 |
The converted files are attached.
Private File Private File |
[2020-02-16 19:28:41] |
HOw do I get them? Thanks |
[2020-02-17 04:51:13] |
Ok, we see you cannot access them. We will set up the access and post here when done.
[2020-02-17 18:19:11] |
Sierra Chart - Max - Posts: 5786 |
Please try again now.
Sierra Chart Support |
