Date/Time: Fri, 10 May 2024 08:23:00 +0000
Save or Queue an order for future submitting
View Count: 493
[2020-02-11 17:03:55] |
User692530 - Posts: 4 |
I would like to be able to set up an order, ANY TYPE of an order (i.e. Market or Limit) and save/queue it for future submitting, have it/them ready in a list. I can do this on IB and I know it can be done on Tradestation so I assume that this can also be done on Sierra, BUUUUTTT I am simply unable to find out how to do this, if in fact it can be done on Sierra. Spent HOURS looking through the crappy documentation without finding ANY mention of it. Colossally FRUSTRATING!!!!!!! Someone please help!!!!!!!!!!! |
[2020-02-12 15:35:56] |
Sierra Chart does have very good documentation. It is possible to submit an order programmatically and have it be held and then use the Send Held command on the Trade >> Trade Orders Window to submit it. However, there is no way to do this for a manually submitted order. We will look into adding this capability but it is not likely we will get to it until a while from now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-12 15:36:35
[2020-02-13 14:40:11] |
Please do it soon!!
