Date/Time: Fri, 10 May 2024 12:19:35 +0000
ICE EU activation
View Count: 544
[2020-02-11 15:20:17] |
User796313 - Posts: 6 |
Hi, Please activate ICE EU data for my account. Also let me know if can access calendar spread data once the subscription is activated. |
[2020-02-11 18:50:41] |
Yes we can do that. Confirm you are fine with the 131.25 USD /month cost. This will be the amount this month. Tell us what underlying futures market you want calendar spreads for. So we can confirm the data is there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-12 06:35:49] |
I need calendar spreads for gasoil and brent. If it is available then please confirm the payment and activate the data. Thank you.
[2020-02-12 19:50:35] |
Yes those calendar spreads are supported. The ICE Europe exchange is now active.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-12 19:50:46
