Date/Time: Mon, 13 May 2024 01:46:13 +0000
Custom Alert Sound
View Count: 1685
[2020-02-11 13:49:42] |
User956467 - Posts: 30 |
I have recorded a .wav file to be used as a custom alert sound for 'Color Bar Based on Alert Condition' study. I have put it in the; SierraChart>>AlertSounds folder but it does not show as an option when in a chart I open Studies - Color Bar Based On Alert Condition - Alerts - AlertSound. Is it possible to use custom alert sounds? How? Thanks!
[2020-02-11 14:54:15] |
bradh - Posts: 857 |
You need to assign the WAV file to an Alert number, which is done in Global Settings>>General Settings>>Alerts/General 3. Then you assign that alert number to the alert study.
[2020-02-12 02:49:50] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Tab_General3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
