Date/Time: Sun, 12 May 2024 21:00:22 +0000
Never Received Email for Free Trial Real Time data feed
View Count: 565
[2020-02-10 18:41:00] |
User352262 - Posts: 4 |
Hi, I started a Free Trial on 2/7 and Never Received Email for Free Trial Real Time data feed. Can you please help? Thanks.
[2020-02-10 19:01:20] |
We do not understand this. There is no email related to a real-time data feed. So we are not knowing what you are referring to. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. You really should start off using the Delayed Exchange Data Feed and do not bother with real-time data now: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-10 19:04:54
[2020-02-10 22:28:36] |
[2020-02-10 22:31:27] |
The markets I want to trade are CME /ES /NQ AND THE /YM (Dow mini) Thanks! |
[2020-02-11 00:33:12] |
Please confirm you are able to receive streaming delayed data feed for those markets now? And, refer to: Delayed Exchange Data Feed: Using Delayed Data to Evaluate Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-11 03:12:03
