Date/Time: Fri, 11 Sep 2026 13:23:44 +0000
Chart setup
View Count: 1047
| [2020-02-10 16:32:10] |
| User276541 - Posts: 2 |
I am new to Sierra and pack 5 and the account is working fine. However, I have not been able to setup the charts the way I want after reading all the documentation which is confusing as a new user. It is mainly the options and appearance of using Numbers and DOM. Can I pay for a service call to have someone login to help make some basic changes and ask a few questions? 15 minutes on a call with an expert would save me hours trying to figure it out on my own.
| [2020-02-13 14:59:48] |
| John - SC Support - Posts: 47843 |
Let us know when would be a good time to call. Also, enter your telephone number or Skype ID where we can get a hold of you on the following page: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-02-27 04:44:50] |
Could you please contact me at 9am Monday 3/2? Thank you Date Time Of Last Edit: 2020-02-27 14:38:45
| [2020-02-27 14:40:10] |
Yes, we will call you then. Note that we call using Skype, so it may show up as not having a number, etc. Be sure to go ahead and pick up at that time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-03-02 16:09:25] |
Called and talked with customer. Helped them get through some of the initial setups and showed them around the software.
| [2024-11-28 13:23:29] |
| ThePatientTrader - Posts: 1 |
Hi John I also need some help can I get a call as well and someone guide me through please anytime after 11 am works for me 305-390-6555
| [2024-12-02 16:17:00] |
This is not something we have the time to do anymore. We recommend contacting any of the people at the following link: Sierra Chart Personal Assistance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
