Date/Time: Wed, 05 Feb 2025 10:51:51 +0000
re Order routing
View Count: 687
[2020-02-10 16:05:52]
User435059 - Posts: 14
Hello !!! can i use you own order routing with any of this brokers ?
i use CTS t-4 , CQG , TT
or work only with TT ?
if i use you data package execution will guaranty ? in case if broker have different price compare to you data ?
it happens with me on IB and esignal , price was not match 3-5 times a day
i see you have issues with CQG ?
can i connect to CQG ? i see only Web Api
i have 5th software package
[2020-02-10 19:50:57]
You are not listing any brokers here. Did you just want to trade the CME group of futures?
We recommend using this order routing service:
Sierra Chart / Trading Technologies Futures Order Routing Service
The brokers that support that service are listed on that page. There are others as well which are unlisted.
And we recommend using this data feed if you just require data for the CME group:
Denali Exchange Data Feed
Date Time Of Last Edit: 2020-02-10 19:52:00
[2020-03-14 20:24:43]
There is a misunderstanding here. The data feed in no way affects execution. So it does not matter that there is some potential difference between what you see with the Sierra Chart data feeds, and what your broker is showing. The Sierra Chart data feeds are low latency and do not lag so long as there is not some Internet connectivity issue.
