Date/Time: Tue, 04 Feb 2025 19:54:39 +0000
Real Time Futures Datafeed
View Count: 862
[2020-02-10 13:54:27] |
User9415867 - Posts: 41 |
I have been looking for a real time data feed for futures contracts to trade the NQ Emini with Sierra Chart. What is the easiest and most cost effective way to do that? I was using the supplied package as my data feed and didn't realize that Sierra only has historical data. I looked at the datafeed providers but TT is extremely expensive. There has to be an easier cheaper way even with TD Ameritrade no longer in the mix. Has SC set up their own futures access for Real Time?
[2020-02-10 17:05:28] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-10 17:12:21] |
I was using TD Ameritrade but that was discontinued. I looked at your link and saw this sentence. "Therefore, to access the CME, CBOT, NYMEX, and/or COMEX real-time data from one of the Sierra Chart Data Feeds at the reduced fees, it is necessary to set the Global Settings >> Data/Trade Service Settings >> Service in Sierra Chart to use one of the supported Trading services or just connect for 10 seconds once a month then back to SC Data-All Services (or the service for your Simulated trading account)." Is there a way to get real time futures data for free or to subscribe to it via SC packages? If not, what is the cheapest one for non professionals that is supported by SC? |
[2020-02-10 18:45:54] |
Therefore the solution is this: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
