Date/Time: Sat, 21 Nov 2026 06:25:16 +0000
[Programming Help] - Reset Condition on New Bar- J72
View Count: 1848
| [2020-02-10 05:45:32] |
| User190501 - Posts: 98 |
Hi Support, Spreadsheet study for trading has this input "Reset Condition on New Bar" that is applicable for the Formula columns. How can we apply a similar condition for the J column. I am setting J72 cell by a condition and would like to reset it after each bar to enable me cancel all working order except the working attached orders. Thanks |
| [2020-02-10 18:37:55] |
This is not supported for the J column.
| [2020-02-10 19:51:46] |
Is there any tip for how a formula in J column reset its condition to false at New bar using coding ?
| [2020-02-12 04:20:57] |
| Sawtooth - Posts: 4362 |
...cancel all working order except the working attached orders.
Use cell J78 for this.Spreadsheet Systems, Alerts and Automated Trading: Cancel All Orders except working Attached Orders (read/write) [v1:J78, v2:J91] To reset at each new bar, try something like this: =AND(FRACTIME(J41)>=FRACTIME(A3),FRACTIME(J41)<FRACTIME(A3)+5/86400) This will go TRUE at the bar open, and go FALSE after 5 seconds. This assumes there is a chart update in the 1st 5 seconds of the bar. |
| [2020-02-13 22:41:38] |
Thanks a lot tomglib for the response. As stated, the objective is to cancel all working orders except attached working orders whenever a condition of new entry holds true. From the main settings of the spread sheet study you can reset K3, M3 at the start of a new bar. for example, if a down bar comes in an up trend , I set entry stop order 1 tick above the high , and got up bar in a down trend, I set a sell stop order 1 tick below the low, this will form K3, M4 conditions --- The same condition but at 4 not at 3 , i.e K4, and M4 is used for the cancellation in J78 as J column cannot accept update from 3 for some reason ! The problem happens if there is a series of down bars after each other in up trend or a series of up bars after each other in a down trend, the conditions for entry will not change as it holds true all the time from 4 stand point in the J column but for sure K3, M3 are reset at each new bar condition. I have added your suggestion and still it doesn't work and the formula is as below ... I would appreciate your kind support.. =AND( OR(K4,M4), AND(FRACTIME(J41)>=FRACTIME(A3),FRACTIME(J41)<FRACTIME(A3)+5/86400) ) |
| [2020-02-14 23:31:40] |
'Reset Condition On New Bar' only applies to Formula Columns. For formulas in Column J: For first occurrence intrabar signals, reference row 3 of Formula Columns. For close-of-bar signals, reference row 4 of Formula Columns. Are your K3/M3 signals intrabar or close of bar? |
| [2020-02-14 23:55:27] |
K3/M4 are close of bar and I also selected signal once per bar.
