Date/Time: Sun, 12 May 2024 15:26:40 +0000
Delete all drawings and SC auto shutdown? Any workaround?
View Count: 612
[2020-02-10 04:39:26] |
User164231 - Posts: 278 |
Chart Drawing Tools: Manage Chart Drawings Hello all, Why is it that when I selected to delete all drawings, SC gets auto shutdown? Also on the column types, even if I select 'locked', 'drawing type', it does not do auto sorting. What did I miss? Thanks. |
[2020-02-10 08:27:27] |
We cannot reproduce this problem. When you have this issue, do not save the Chartbook, and then attach that Chartbook here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile And tell us the chart number (#) this occurred with. Sorting is not supported in the drawing list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-10 08:27:45
[2020-02-10 13:48:17] |
It should be either the countdown timer and/or symbol display. Both appear as text on manage chart drawing.
[2020-02-10 22:12:09] |
Sierra_Chart Engineering - Posts: 14320 |
We cannot reproduce any problem. We need you to update to the current version following these instructions: Software Download: Fast Update Do not post further about this unless you update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
