Date/Time: Sun, 19 May 2024 02:02:04 +0000
force redraw toolbar / acs buttons
View Count: 518
[2020-02-09 02:08:21] |
User735389 - Posts: 188 |
is there a way to do this? when i apply a change to the acsbuttons (like color), the changes dont apply until i somehow force a redraw. I'm doing this now by changing the physical width of an acsbutton with random text.
[2020-02-09 23:33:58] |
This should not be a problem. Update to the current version and let us know if you still see an issue. If you do, provide the line of code of affecting a control bar button that does not immediately go into effect.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-09 23:34:21
