Date/Time: Mon, 25 Nov 2024 03:06:09 +0000
kagi
View Count: 1822
[2014-01-06 09:33:04]
User19052 - Posts: 13
periodically I see strange buildings on kagi chart, is this normal?
Date Time Of Last Edit: 2014-01-06 20:47:15
imagekagi.jpg / V - Attached On 2014-01-06 09:30:50 UTC - Size: 202.88 KB - 400 views
[2014-01-06 18:30:01]
any comments?
[2014-01-06 19:30:13]
Usually this problem is because you do not have a tick by tick data configuration:
http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php
[2014-01-06 19:46:16]
it was actively, check personally on the long time - 10-20 minutes and you will see the problem
[2014-01-07 07:55:39]
there will be some comments?
[2014-01-07 10:10:36]
and today i too see its bug ;-(
imagekagi2.jpg / V - Attached On 2014-01-07 10:09:24 UTC - Size: 371.14 KB - 412 views
[2014-01-07 20:02:55]
We need time to review this.
[2014-01-07 20:16:22]
We have looked into the problem, confirmed the issue, and we will resolve it.
Actually the problem is because the underlying chart bars are set to 1 Tick (Number of Trades = 1). A temporary solution will be to set them to 1 Second.
Date Time Of Last Edit: 2014-01-07 20:38:56
[2014-01-07 20:36:17]
We can report, that we do have this problem now resolved. If you would still like a refund, we can do that.
We can put out a new release at the end of the day for you to test. So you may want to wait before canceling, so you have time to test this new version.
Date Time Of Last Edit: 2014-01-07 20:36:47
[2014-01-08 12:21:53]
hi
I'm testing a version in 1075 and it seems the problem was solved with kagi chart, thanks for the timely response
