Date/Time: Sun, 19 May 2024 02:17:45 +0000
ACSIL spread trading system
View Count: 830
[2020-02-08 07:29:31] |
MattK - Posts: 42 |
Hi, I'm trying to figure out a way to create a spread trading automated system. So far, the only way I see is to create a system for each symbol independently and put the same conditions and then look up the backtested results for each symbol and compare. Is there a simpler way and less problematic way to do it? That would be great! :) Many thanks in advance. Best regards, Matt |
[2020-02-10 08:26:23] |
Yes use this feature to create the spreads: Custom Calculated Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
